Coding replacement RT3 - cant find ECU in lexia
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
Harlequin
x 24
Unread post by Harlequin »
As title , trying to pair the radio to my c5 , it all works with the beep beep beep, but when i run diagbox, it cant find the radio ecu, so i cant start to pair it?
Reason: Moved Thread to RT3 Forum and Corrected Titles
Simon
x 6955
Re: Coding replacement RT3 - cant find ECU in lexia
Is this the original unit or have you replaced it with a second hand unit from another vehicle? If so, what system did you originally have (VIN would be preferable), as if the unit is not identical there are multiple options that have to be set before you can even start to configure the unit.
Harlequin
x 24
vin is VF7**************[VIN obfuscated, can be read by forum staff]
car has replacement dash (sat nav), from an 07 reg c5. It came with RT4 head unit and all the cabling - it all is hooked up, it all works just the beeping!
I used a pin out for the rd3 to rt3 quadlock (do you have the pin out for the navidrive quadlock?)
Simon
x 6955
This is for a 2005 RT3, with Colour Screen, but of course the aerials won't be the same as the original ones you had for the RD4 the car came with, (GPS / GSM etc.)
Harlequin
x 24
Thank you - all hooked up as expected!
What about the beeping?
Simon
x 6955
That will need VIN coding to stop the beeping. You’ll need to locate the RT3 / RT4 ECU and then enter the configuration menu to code it in at the relevant section.
Harlequin
x 24
lol - and when lexia cant find the radio ecu?
Simon
Harlequin
x 24
All sorted, had to uninstall the cd and install telematics! BUT, now the screen is black and doesnt turn on? any ideas what ive managed to do?
Simon
x 6955
You need to be very careful what you change there as there's no undo!
Don't change anything unless you are 100% sure you know what you're doing as some options (and the way they are written) do not mean what you think they do!
The best thing you can do is to Screen shot me the relative pages of the configuration that you have changed so I can check if you have it set correctly for RT4 (and the VIN of the relevant vehicle).
Harlequin
x 24
vin will show a non sat nav car - this is a refit from another car.
i think its all configured properly, its just the screen doesnt start. Have done a bsi reset as well
Simon
Tomas1
x 11
Unread post by Tomas1 »
Harlequin wrote: 15 Dec 2022, 21:26 lol - and when lexia cant find the radio ecu?
Diag box can be used on vehicles after 2008.
If you use diagbox, try Lexia (vehicles up to 2007)
Harlequin
x 24
sigh, still a black screen. ALl functions as expected, even the nav talks, just no screen out put.
Yes it worked before i tried to vin code it :(
Simon
Harlequin
x 24
Marc - still fighting with this; will it be changes to the hdd software , or bsi or engine ecu that knocked the screen out?
If the above - would a blind update of the software from scratch (2 white buttons) help?
If not, would a bsi update to `as built` (excuse the Ford terms), then update it again fix it?
Simon
x 6955
I can't see all the data on your first picture - half the screen is missing on the left. Please upload the pictures directly to the Forum (use the Full Editor & Post button, then select the Attachments tab at the bottom to browse, upload and place your images.
Also, what other options have you got when selecting the screen - it currently shows Standard DeV - what are the available options as there are 2 types of display for telematic units. You poreviously only had RD4 display, so have you got the correct wiring cables for the RT4?
Harlequin
x 24
you reminded me , need to pay this years subs for the forum!
Its literall grey as the laptop bezel is to the left , its a photo of lexia from diagbox ; can take a new one if you want?
Simon
