Hi guys,
Anyone got a starter circuit wiring diagram for a 2017 Citroen Relay? I've only got 7v at the solenoid on the starter motor and I'm trying to work backwards from there but I've had some conflicting advice regarding stater relays etc.
Thanks,
Starter circuit wiring diagram - Citroen Relay
The Viking
- x 3
Re: Starter circuit wiring diagram - Citroen Relay
Have you checked that you have a good engine ground and that both battery terminals are tight
- x 3296
It might be worth checking the heavy duty cables as well. It would be unusual (for such a new vehicle) but the cables can and do 'break down' over time (so the resistance goes up). Here is a thread about them;
https://www.frenchcarforum.co.uk/forum/ ... hp?t=38273
