Hi All
Hope someone can point me in the right direction currently getting codes
P0087
P0093
This happens a few minutes after driving fault code P0087 causes the car to go into limp mode
P0093 causes the engine to stop
Using Diagabox 9.83 and obviously both are related to Fuel circuit
Haven't changed the Fuel Filter will try and do that Monday as my first / easiest option any other pointers would be appreciated
Many Thanks
Peugeot 207 1.6hdi P0087 and P0093
- x 1478
Re: Peugeot 207 1.6hdi P0087 and P0093
Both low fuel pressure codes. Def change the fuel filter first. If it persists may be a leak off fault with an injector or the fuel rail pressure sensor itself
gango67
- x 3
Thanks for reply changed fuel filter this morning so far so good all seems back to normal
- x 1478
Nice one, they do complain when the filter starts to get plugged!
