ZDDP engine oil discussions for XUD engines
makemine205
Unread post by makemine205 »
Where are the discussions for ZDDP engine oils for the XUD engine discussions and engine rebuilds and new cam break in oils info ?.
x 8148
Re: ZDDP engine oil discussions for XUD engines
You may find some guidance here: :)
viewtopic.php?p=596442#p596442
x 1943
Unread post by Paul-R »
What's ZDDP?
x 5675
Zero Dirty Diesel Pollution
x 8148
Have a look at this Paul:
"ZDDP’s primary role as a sacrificial anti-wear agent is to prevent wear throughout the engine in areas such as bearings, tappets, cams, piston rings and valve stems."
I found it here:
https://www.duckhams-oils.com/zddp-what ... -all-mean/
x 1943
myglaren wrote: 06 Dec 2022, 13:43 Zero Dirty Diesel Pollution
Looks to me to be a petrol engine issue. Not many diesel engines use leaded (or unleaded!) petrol.
x 8423
Paul-R wrote: 06 Dec 2022, 13:54
I've been known to use petrol to clean particularly dirty diesel engines ;) They nicely ended up ZDDP with all the P going in the bin in the form of dirty, oily rags...
makemine205
I only found this out the other day so i,m learning about it. Apparently theres been a spate of cam break in failures in the US by engine builders over the years its also been mentioned in piston aero engines .
Some people think its crappy cam and lifter engineering ie chinesium , off shore farmed out products others think its the Zinc that has been reduced in engine oils over the years as it was destroying the cat convertors ?. I,m just wondering if anything like this has occurred in the french car engine rebuilds / collectors cars older engine technology with failed cam break ins ie a wiped out new cam and lifters / tappets ?.
