I think I've spiked my ECU!!
onejon1
x 4
Unread post by onejon1 »
I think I've spiked my ECU!! Can you help to get the car running again, please?
Below is a video of what the car does when turning the key.
There are no blown fuses, as I've checked all the ones under the steering wheel and in a box that's inside the engine.
Kind regards
Jon
Peugeot 306 2001 HDI meridian
Engine Size 1997cc
Cylinders 4
Valves 8
Fuel Type Diesel
Transmission Manual
Gearbox 5 Speed
Drivetrain Front wheel drive
https://youtu.be/WW-Jkek9a3k
Ross_K
x 110
Re: I think I've spiked my ECU!!
Unread post by Ross_K »
I vaguely remember seeing a post a long time ago about the flashing 8s on the odometer and "wagging" gauge needles having something to do with a fusebox fault (a bad solder joint or something like that?).
Disconnect the battery and come back to it in daylight tomorrow
x 6953
Are the speedo dials flying up and down too? One symptom of the lights going haywire, clicking and the speedo dials moving rapidly is the main car battery needing changing.
Michel
Unread post by Michel »
You need a new battery.
onejon1
x 4
Michel wrote: 27 Nov 2022, 23:46 You need a new battery.
you are so right, charged it up and the battery appears to of survived.
