Subframe and rods (207)
siponof802
Unread post by siponof802 »
Hello, want to swap subframe into 207 1.4 petrol verve with available one from 207 1.6 hdi allure. Will be compatible? Look is the same but do not want to experience small difference and then redo the job and it is to remote to measure the hdi one and my without at least a bit of disassembly. Many thanks.
Ps. question is same for tie rods and wishbones. Are they same? As they would come with the frame so less hassle.
If there is manufacturer that do same one new in reasonable price i would be happy to hear that too as i could not find replacement new ones
x 6954
Re: Subframe and rods (207)
The part numbers for the subframes on the 207 changed from several build dates, however the replacement part number this changed to and the current part number is the same for all models.
siponof802
Thank you very!
