Dipped headlight failure
Tofwig
Unread post by Tofwig »
I've just had my dipped beam go.
Full beam works
Side lights work
But if I turn dipped beam on, nothing happens.
Just this minute stopped🤷???
Reg CN18 MPO
x 3298
Re: Dipped headlight failure
I would check that both bulbs have not blown. If one bulb fails you may not notice it (unless you are doing regular checks), but when the second bulb fails it then becomes obvious that the two have failed.
Tofwig
Thanks for the reply. Both bulbs were working when I set off, so I'm certain it's one wasn't out.
I'll check tomorrow if both of the bulbs have gone, what's the chances of that happening?
Piece of **** this van is🤣
Reason: Moderated for language
