Injectors
PaulVmax
Injectors
Unread post by PaulVmax »
Hello All,
I think my Old 1.9 expert is terminal. I want to try one last think before I condemn it. I was wonder if any one knows what injector seals and glow plug seals i need for a 2005 expert 1.9d.
x 8275
Re: Injectors
What's the problem with it Paul?
Generally, glowplugs have no seals as they have a taper seat similar to some types of sparkplugs...
Injectors normally use copper washers especially sized and designed for the job. If you know the kind of injector then finding the correct seals will be no great problem...
Pop your VIN up (don't worry, it'll only be visible to forum staff) and that may enable a seal part number to be given...
