Hi.
I got a warning on the display, Gearbox Fault and the Service light is on.
Its stuck in 3rd gear and the sport and snow light is flashing. The next day the car was fine but it has happend 2 times more.
I have had a look at the codes and the gearbox error code is P2728.
The car is a 2011 citroen c5 2.0 HDI.
Gearbox fault.
- x 1493
- x 1468
Re: Gearbox fault.
It would help to know which transmission you have, probably an AL4 or AM6.
It could be a faulty pressure control valve in the valve block, or anything else that causes the hydraulic pressure in the transmission to be low. Perhaps even low fluid level.
More information is needed.
Qube90
Re: Gearbox fault.
Its a am6 gearbox.
If I understand it correctly the faulty code p2728 is pointing to valve slc3 .
