Peugeot 206 gti 180 DBW and Pedal wiring diagram
Grady
Unread post by Grady »
Hello
I am in need of the wiring diagram for a 2005 206 gti 180, i need the diagram that shows the pinouts for the DBW throttle body and the Pedal.
the car is having an aftermarket ECU installed by myself and I would like to retain the stock pedal and throttle body, however im stuck without the above info.
Hoping for a life line, VIN number - VF3**************[VIN obfuscated, can be read by forum staff]
x 6963
Re: Peugeot 206 gti 180 DBW and Pedal wiring diagram
Here you go:
Use pin assignments, not wiring colours as they can change.
Motorised Throttle Body
Wiring
1262 is the Motorised Throttle Assembly
1335: Intake air electric motor command (-)
1334: Intake air electric motor command (+)
1367: motorised butterfly potentiometer earth
1219: throttle potentiometer position signal 2
6784: Throttle position sensor + power supply
1218: throttle potentiometer position signal 1
Accelerator Position Sensor
Wiring
1261: Is the Accelerator Position Sensor
1377: Accelerator pedal 1 position info
1379: Engine management diagnostic indicator light command
1378: Accelerator pedal 2 position info
1380: + 5 volt accelerator pedal position indicator power supply
1320 Is the Engine ECU
Grady
Thank you for that Marc, this is extremely helpful information!
