RT6 problems
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
slneshev
RT6 problems
Unread post by slneshev »
Hello! Recently I did firmware update on my RT6 to 2.86B. I own Ds5 from 2013. Everything was fine until I found out that 2 of the buttons have swapped functionalities. I asked a friend and he said it could be fixed with diagbox but I dont own one right now. My question is is it possible to do it through Mirascript. The two buttons are the one for FM/AM band and the equalizer button(the one below band). Also my mute button doesnt work. And on the dashboard when selecting the screen for gps it says zone not mapped and radio off while the radio is ON and the zone is mapped. Any help will be appreciated.
x 6947
Re: RT6 problems
I'm not sure if Mirascripts can do all that is necessary, nor will Diagbox in non-connected mode.
The RT6 has gone into secure mode which happens if you are going from some versions of previous firmware to a newer major firmware update. Diagbox will not be able to reconfigure these options without access to PSA servers for configuration (so not possible in offline mode). So it may be a dealer visit for them to re-configure it in online mode.
