Aditive pump
Mistique
Aditive pump
Hello everyone! An error appeared on my car, engine fault need repair. I put the tester on and it shows that the additive pump is no longer communicating with the ECU. I took the additive tank down and noticed that I have about half a tank left. Some time ago this error appeared again but after a few days it disappeared by itself. The car is a Peugeot 5008 2.0 hdi 2011.
- x 6945
Re: Aditive pump
I'd be checking the wiring connections to make sure they are not shorting or damaged. Also, if the pump has had the wrong additive type, this can cause a blockage and pump failure. Dry running can then cause a failure. Probably best to have it diagnosed for a fault code and then put that up here when you have it.
