Difference between DW10BTED4 (RHJ) and (RHR) Engine
Grand-Picasso-2010
Unread post by Grand-Picasso-2010 »
Hi
Does anyone know what the Difference between a DW10BTED4 (RHJ) and a DW10BTED4 (RHR) Engine is
And what would need to be done to a DW10BTED4 (RHR) engine to fit into a car with a DW10BTED4 (RHJ) engine
Thanks for your help
x 6948
Re: Difference between DW10BTED4 (RHJ) and (RHR) Engine
Different torque
RHJ 1997 cc (138 hp) DW10BTED4/E4 with particle filter (270 Nm) (BVMP) (Piloted Manual GearBox)
RHR 1997 cc (138 hp) DW10BTED4/E4 with particle filter (320 Nm)
Grand-Picasso-2010
Thanks Marc
Do you know if i can take a DW10BTED4 (RHR) and reaplce an engine in a car with a DW10BTED4 (RHJ) and what parts/sensors will need to swaped over?
x 6948
I suspect as a minimum the engine management ECU will need configuring as a minimum and the certificate of conformity for the different engine may also need to be provided as the vehicle will no longer meet the original certification for road use / emissions etc. There may be other things, but I can’t advise at that level of detail.
Grand-Picasso-2010
Hi Marc
thanks
it sounds like it more trouble than it’s worth or just not possible to use a RHR engine but i wish that wasn’t the case as the RHR engine i have found is more common to get a hold of.
