Hello friends, my 2009 Citroen C4 has ESP and ASR fault. Codes are U1305, C1311, U1325, U1105, U1125.
I have changed the Yaw sensor, but it still shows Yaw sensor signal fault.
My VIN number is VF7**************[VIN obfuscated, can be read by forum staff]
2009 Citroen C4 ESP/ASR error (Solved)
smallweapon
- Locked user account
- Attachments
smallweapon
Re: 2009 Citroen C4 ESP/ASR error (Solved)
Hello friends, problem solved. the fuse 4 in the dashboard was keep on shorting out. And it was caused by the broken monochromatic (auto-dimming) rearview mirror. The windshield was not sealing very well, and water got in and damaged the monochromatic (auto-dimming) mirror. And apparently, the ESP gyroscope meter/yaw sensor runs off the same circuit as the monochromatic (auto-dimming) mirror. The monochromatic (auto-dimming) mirror's wiring plug was removed and the problem is solved. Currently, I am just using the mirror as a normal mirror with no auto-dimming function. I am just going to leave it as is. Thanks for all the help guys.
- x 3298
Well done for finding the problem, and thanks for updating the Forum.
Oh,
to the Forum, by the way.
Oh,
