Hello,
I am have this problem with my C4, i have changed the battery and the capacitor accumulator and the error is still there is there a fix for this problem.
Kind regards
Mel Wright"
Error P1A9C stop start accumulator
- x 6946
Re: Error P1A9C stop start accumulator
This can generally result in several solutions:
1) Check the tightness of the cable nuts on the central voltage maintaining device.
2) You need to use the specific guided procedure "Replacement of the energy storage battery or of the voltage maintaining device" using Diagbox.
MelC4
Okay I will try it out all tips welcome
Cheers thank you.
Cheers thank you.
MelC4
Hi I managed to clear the error P1A9C and now there is error U1134 any ideas how to fix this 1.
thangviet
Out of curiousity, how did you manage to clear/fix the P1A9C and are you getting any other errors aside from U1134 (LIN network issue?)MelC4 wrote: 23 Nov 2022, 12:06 Hi I managed to clear the error P1A9C and now there is error U1134 any ideas how to fix this 1.
MelC4
Hi a mechanic with his Diagbox tool registered the replacement stop start capacitor now I have these 2 errors U1133. & U1134.
dennisjr2k5
Hi, MelC4. I'm having the same problem of P1A9C, how did you clear the error? thanks
MelC4
Hi sorry for the late reply, i replaced the stop start capacitor.
- x 6946
I've only just picked this up, however as you've said you have had the Voltage Retaining Device replaced, you need to be aware that you can't just replace it. It needs programming with Lexia / Diagbox or you'll likely end up with faults. So has he properly done everything required using the diagnostic tool? There should be a guided procedure to do this. I ask this despite what you've said about him 'registering' it, but as you can see one of these faults refers to the device as absent....MelC4 wrote: 26 Dec 2022, 06:23 Hi a mechanic with his Diagbox tool registered the replacement stop start capacitor now I have these 2 errors U1133. & U1134.
| Fault Code: | U1133 |
| Description of Fault: | LIN: The reversible alternator is confirmed absent. Faults in communication between ECUs on the LIN. |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U1134 |
| Description of Fault: | LIN: Voltage retention device confirmed absent. Faults in communication between ECUs on the LIN. |
| Symptoms: |
| Suspect Areas: |
MelC4
Hi Marc I did replace the stop start Ecu then that cleared the other 2 errors its 1 year now and working fine no more problems, apart from a fuel gauge registering problem this week that I have caused by topping up with 8 litres to fill the tank is there a fix for this problem it shows 2 clicks short with full tank of fuel.
- x 6946
That issue can sometimes clear itself, but can be avoided by not filling past the 'clicks' when adding fuel.
Try allowing the tank to run down to a quarter full, then filling up to the first click only. See if that restores the gauge correctly.
MelC4
Ok thank you I will try that.
dennisjr2k5
It's, okay. Will try this approach, thanks a lot/
Ibiza
2012 Citroën C4 1.6 e-HDi (stop/start).
Engine fault repair needed + service light on.
Code: P1A9C – energy accumulator fault.
Battery is good (12.4V off, about 15V running).
Changed the IBS (battery sensor) – no change.
Code clears but comes back.
Before I change the alternator, could this be the capacitor or wiring?
What’s the proper way to test it?
