As above, the coolant appears to be a yellowish colour, on looking in car parts store there seem to be a bewildering array of colours and contradictory fitment information!
Can someone tell me which is correct? I intend to flush and refill.
Many thanks!
What Antifreeze should my C8 have?
Doo
- x 121
Re: What Antifreeze should my C8 have?
Generally, it should be OAT (Organic Acid Technology) which is orange. I wonder if someone mixed in some bluePeteC8 wrote: 26 Oct 2022, 10:09 As above, the coolant appears to be a yellowish colour, on looking in car parts store there seem to be a bewildering array of colours and contradictory fitment information!
Many thanks!
I's fine to have a bit more coolant than water. I do it and it doesn't harm any of our vehicles. I get astonished at Aussie truckers wondering why their engine blows hoses and overheats... I end up swearing at the tv, telling them to add coolant as it raises the boiling point ....
Has anyone seen the plot?
jscadden
- x 4
It is also a good idea to keep the antifreeze topped up all year as it contains anti-corrosive chemicals which prolong the life of the cooling system.
John
Xsara Picasso VTX 16V
VIN VF7**************[VIN obfuscated, can be read by forum staff]
PeteC8
- x 3
Thanks very much John.jscadden wrote: 26 Oct 2022, 15:09 It is also a good idea to keep the antifreeze topped up all year as it contains anti-corrosive chemicals which prolong the life of the cooling system.
When I got the car earlier this year I dropped some antifreeze due to having to remove a pipe to get access to a stroppy starter motor!
I topped up with water, every time I looked into the subject I got confused, but now the cooler weather is approaching, I needed to get the experts advice!
PS: I understand the benefits of keeping the antifreeze strength up, this hasn't been sitting easy on my shoulders!
PeteC8
- x 3
Thanks very much for the info, orange it is then!!Doo wrote: 26 Oct 2022, 11:59Generally, it should be OAT (Organic Acid Technology) which is orange. I wonder if someone mixed in some bluePeteC8 wrote: 26 Oct 2022, 10:09 As above, the coolant appears to be a yellowish colour, on looking in car parts store there seem to be a bewildering array of colours and contradictory fitment information!
Many thanks!![]()
I would be inclined to drain it out, flush through with water, then connect everything back up and put in new antifreeze. It's generally a 50/50 mix, but coming up to winter you'll get away with 60% OAT & 40% water.
PPS: I try to avoid all those staged semi reality programmes now as I used to react like you and while the scales of size and accessibility of Australia is a fascinating subject, my blood pressure comes first!!
- x 2374
I've been racking my brain as something was niggling me about the above! Bit of Googling helped, you are quite correct antifreeze does increase the boiling point.Doo wrote: 26 Oct 2022, 11:59 I's fine to have a bit more coolant than water. I do it and it doesn't harm any of our vehicles. I get astonished at Aussie truckers wondering why their engine blows hoses and overheats... I end up swearing at the tv, telling them to add coolant as it raises the boiling point ....
But there is a negative - antifreeze has a lower specific heat capacity than pure water, so you are loosing a little cooling capability at an increased concentration.
Which is the dominant factor I'm not sure?
https://www.motortrend.com/how-to/glyco ... r-coolant/
Matt
- x 8462
I can only speak of blue ethylene glycol Matt but the recommendation is not to exceed about 35% as cooling efficiency becomes compromised...MattBLancs wrote: 26 Oct 2022, 18:55 But there is a negative - antifreeze has a lower specific heat capacity than pure water, so you are loosing a little cooling capability at an increased concentration.
It's interesting to see that some users of 'waterless' coolant have encountered overheating problems in classic cars... Presumably for the same reason. They revert back to ethylene glycol and problem solved...
