RD45 - General
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
secretstar
RD45 - General
Unread post by secretstar »
Hi guys can someone help me out if i tell the V?N number of my car wich radio original compatible is with my vehicle? ? know there are different types of RD4 and RD45 car radios on the market. How can i be sure? ?f it was possible to upgrade to RD45 i've noticed this two different part numbers on this radio. RD45 L3FA04 CEM00 and RD45 L5FA04 CEM00. Any idea about the difference?
x 6950
Re: RD45 - General
Upgrading to an RD45 will very likely require you to wire in a separate microphone as the factory-fitted one is integrated into the vehicle harness and may not be available at the output end.
The RD45 may have different functionality depending on country / build / vehicle. You may also need to replace your multifunction screen if you currently only have the RD4 installed and it will need configuring and VIN coding to operate correctly.
