Saxo indicators wiring diagram
bkod
x 7
Unread post by bkod »
Hi.
Wondering if anyone with access to SEDRE would be able to help me... My laptop refused any further cooperation so can't check it myself. I would need wiring diagram for Saxo indicators...
Ben
x 8309
Re: Saxo indicators wiring diagram
Why? What's the problem with them?
Huskyxantia
x 878
Unread post by Huskyxantia »
Knowing the saxo the wire under the splash guards rotted . Happend to my one 8 yr ago , nice green wire !
:-D
bkod
x 7
CitroJim wrote: 19 Oct 2022, 18:07 Why? What's the problem with them?
[/quot
e]
The indicators and hazards just stopped working. I have replaced relay but no success. The hazard switch seems to be ok according to my multimeter...
It's 04 plate which sat for at least a year. Bought it for my son as first car and I'm sorting it step by step... Some issues were solved by new alternator connector. That didn't solve the indicators issue...
bkod
x 7
Huskyxantia wrote: 19 Oct 2022, 20:06 Knowing the saxo the wire under the splash guards rotted . Happend to my one 8 yr ago , nice green wire !
What do you mean by splash guards?
Huskyxantia
x 878
Wheel arch liners, try jacking up the car, remove front wheel then move wheel arch liner to gain access to the back of the side indicator in the wing , my old saxo indicator wire had rotted i had to cut out the green coloured wire and splice new wire plus new bulb holders this sorted my problem , also check all earth points behind headlights and the rear lights , not to mention fuse terminals.
:-D
bkod
x 7
Huskyxantia wrote: 19 Oct 2022, 21:34 Wheel arch liners, try jacking up the car, remove front wheel then move wheel arch liner to gain access to the back of the side indicator in the wing , my old saxo indicator wire had rotted i had to cut out the green coloured wire and splice new wire plus new bulb holders this sorted my problem , also check all earth points behind headlights and the rear lights , not to mention fuse terminals.
That wouldn't make all the indicators to stop working, would it? They were working, one day just stopped...
I'll have to check everything bit by bit and that's why I was hoping for diagrams. My laptop with SEDRE installed on it died recently and I can't find the DVDs to install it on another...
Huskyxantia
x 878
Do it the old fashioned way, check the wires to each bulb holder and follow the wire to where it goes for any breaks, even the loom in the door can cause all types of electrical issues so they might be worth a look, heres some links to some car electrics i know the stalk can be sebsepterble to damp .
Some links below might shed some light
https://fuseandrelay.com/citroen/saxo.html
http://www.saxperience.com/forum/showthread.php?t=24339
http://www.saxperience.com/forum/showth ... p?t=449780
:-D
bkod
x 7
Huskyxantia wrote: 19 Oct 2022, 22:28 Do it the old fashioned way, check the wires to each bulb holder and follow the wire to where it goes for any breaks, even the loom in the door can cause all types of electrical issues so they might be worth a look, heres some links to some car electrics i know the stalk can be sebsepterble to damp .
Thanks for the links. It looks like there's one I needed. Thank you very much!
Huskyxantia
x 878
If you do get it sorted pop your end results up on here as it will help others
:-D
x 1056
Unread post by wheeler »
Would need either the reg, VIN or at the very least the RP number to get the correct wiring diagram for your car.
bkod
x 7
wheeler wrote: 20 Oct 2022, 22:39 Would need either the reg, VIN or at the very least the RP number to get the correct wiring diagram for your car.
Great! Thanks!
Reason: VIN obscured
x 1056
Got it, will get a diagram later this afternoon when i get home.
x 1056
Heres the diagram.
If you have a total loss of indicators/hazzards the first thing i would check is you have a battery live at pin 3 of the hazzards switch & an earth at pin 7
bkod
x 7
wheeler wrote: 21 Oct 2022, 14:17 Heres the diagram.
Thank a lot! I'll be working on it on Sunday. I'll let you guys know the results 😉
