Hi All,
I'm after a little advice in trying to determine and resolve an issue that I have with my fuel gauge on a 2017 citroen spacetourer/Dispatch van.
My fuel gauge seems to be stuck on half a tank for an eternity then it will all of sudden drop to quarter then you look again it be back up to halfway.
Any ideas how to fix this or what the issue could be?
Citroen spacetourer fuel gauge problem
- x 1061
Re: Citroen spacetourer fuel gauge problem
BSI reset would be the first port of call.
Bobspace21
Thank you for your reply.
I forgot to mention that I have an issue with my battery draining down and a error code being displayed. Apparently the auto electrician couldn't find the drain after pulling all the fuses and replacing the battery. However a new BSI was ordered but that was 5 months ago and still part isn't in stock.
So would you suggest this the fuel gauge issue could be down to a faulty BSI and not the actual fuel sensor itself?
Also would you have the BSI reset procedure to hand so I can try resetting it see if that help.
Thanks.
Thanks.
