Sump plug location xantia hdi 110 late 98
ianb875
(Donor 2022)
Unread post by ianb875 »
Set out to do an oil change, only to find there are 2 bolts where I thought the sump bolt is. Can someone tell me which of these 2 I am supposed to undo. I was assuming the bottom one but, frankly I am mystified.. can someone help please?
x 2374
Re: Sump plug location xantia hdi 110 late 98
Unread post by MattBLancs »
It's the lower one. My (90 bhp) 306 has two, too. Always wondered what was behind the upper one but never unscrewed it for a look or had need to take the sump off where could have seen it from the inside.
Matt
x 1506
I think it's for an oil temperature sensor.
ianb875
(Donor 2022)
Thanks for your replies. I shall remove the lower one to drain the oil. As to the top one, I note the suggestion that it could be for oil temp sensor, but my car actually has one of these but wherever that connection is, it is not to the top plug on my car.
Huskyxantia
x 933
Unread post by Huskyxantia »
Sump drain plugs will be the lowest ones on the sump . 24mm nut i think. Was a while back when i had my xantia , nice cars wished i still had my one.
:-D
