My 2010 Cit C3 picasso has had the ABS warning light on. Diagnostics gave code for front driver side ABS sensor fault. So replaced the cable this morning but warning light keeps coming on even after clearing code.
What would be the next diagnostic?
Someone told me sounds electrical and another said it might be worn bearings.
What is the best path to go down??
It might be related but I hear some funny squelshy noises from the front wheel area when driving (not clunking which I would know is driveshaft)
Cit C3 Picasso ABS problem
- x 1506
Re: Cit C3 Picasso ABS problem
Does it come on right away or only when you are driving? You can have a look at the bearing and see if the mag track looks damaged (or not present!) - if you can get live data in your scanner you should be able to look and see what the wheel speed is showing as.
