Citroen dispatch 2009 1.6hdi fuel pump relay location does anybody know or have a schematic cheers
Gasman
New User
Unread post by Gasman »
Citroen dispatch fuel pump relay fault
x 1052
Re: Citroen dispatch 2009 1.6hdi fuel pump relay location does anybody know or have a schematic cheers
Unread post by wheeler »
It doesent have one as such, it's integral to the under bonnet fuse box.
Not sure if you are referring to an in tank pump or the electrical bits on the mechanical high pressure pump on the engine?
Just be aware that your vehicle may not actually have an in tank pump.
Either way both the power to the in tank pump (if fitted) & the power to the electrical bits of the mechanical high pressure pump come from the under bonnet fusebox.
