RADIATOR QUESTION
surfer
RADIATOR QUESTION
Unread post by surfer »
I am about to replace the rad on my Xantia Activa.
The top and bottom hoses appear to have a steel sleeve/fitting on the end which pushes into the radiator pipes.
These are then held in place by a large wire spring clip.
My question is are there any o rings used in this assembly? My local dealer didn't inspire any confidence when they said no, and the Haynes manual mentions nothing either.
I just want to be sure that I don't need anything other than the new radiator to get this job sorted.
Thanks,
Simon.
Richard Gallagher
Unread post by Richard Gallagher »
No, there are no 'O' rings, you just push the pipe in until the rather flimsy spring clip catches.
I didn't have much faith in the system but it does work.
You will have some fun re-fitting the hose on the offside..................
