Hey all.
Can anyone help me with info regarding correct hydro suspension unbleeding procedure.
At the moment i have changed front spheres but i dont have lexia and no official dealership around. I need to unbleed the system as car is undriveable. Pump works fine, but car is so soft , doesnt absorb any road bumps etc.
I think it just needs to be unbleeded, LDS level is ok; no leaks; only i get some small noise when turning wheel til the end (no matter, left or right).
Any help?
CITROEN C5 X7 2009 SUSPENTION SYSTEM UNBLEED PROCEDURE WITHOUT LEXIA
Jaunais
dulenator
- x 11
- x 1463
Re: CITROEN C5 X7 2009 SUSPENTION SYSTEM UNBLEED PROCEDURE WITHOUT LEXIA
Are you sure that the new spheres are the correct specification for the car, and fitted to the correct locations?
Air in the system usually causes a harsh ride, not soft damping.
Jaunais
found out there is no air in the system and problem is still unsolved. Dont know where to look for help...xantia_v6 wrote: 08 Sep 2022, 20:29 Are you sure that the new spheres are the correct specification for the car, and fitted to the correct locations?
Jaunais
From random OBD computer when connected i receive error codes: U1213; U1116; U2005
