Rear suspension pipe.
Bill c5
Unread post by Bill c5 »
Hi guys
my car is now immobile its a 2009 C5 111 X7 fantastic car but a pipe has burst at the rear and i cant get one its the 5270vp center rear pipe.
can anyone suggest where i can get one?
thanks Bill
Reason: Moved out of Introductions to Technical Forum
x 6945
Re: Rear suspension pipe.
Hi Bill
That is one of the pipes that is still showing as available direct from Citroen, so I suggest you contact them as you won't get these new from elsewhere, being that they are bespoke pipes.
Jay-Bruce
x 280
Unread post by Jay-Bruce »
I'm out at sea just now, so can't do anything to help you just yet, however if your stuck and can't get anything by say 19th of this month, drop me a line. The reason being that I'm developing a solution for replacement LDS pipes meaning that I am possibly in a position to hook you up with a cuni pipe to replace this pipe --> hose --> pipe assembly.
Lenny
x 62
Unread post by Lenny »
Hi Bill,
The old pipe may be repairable by a hydraulic hose company (I've just Googled 'hydraulic hose repair Stirling' and there's a good few options in your neck of the woods).
I had one of my rear suspension pipes repaired for £25 a few years ago and it was still fine 3 months later when I finally got around to fitting a proper replacement.
