Lhm filter clips!!!
paranoid
Lhm filter clips!!!
Unread post by paranoid »
Can anyone tell if you can get, the metal clip that holds the filters to the top part of the LHM tank, mine pinged somewhere when I put the hydra flush in, And the D shaped filter has dropped loose in the tank, or does anyone know a fix, I can't be the first one to do it!!
uhn113x
x 3
Unread post by uhn113x »
It is only a bent bit of spring steel wire....
AndersDK
Unread post by AndersDK »
This spring I believe is part of the manifold assembly, but correct me if I'm wrong.
My best bet is a visit to nearest breaker.
