Hi all,
I'm looking into buying used Citroen C4 Grand Picasso. I saw one interesting car. Now, I would like to see full list of equipment. I have its VIN code, but interestingly carvertical didn't help me. It printed out basic information, but nothing more in terms of equipment.
My questions are:
can I find somewhere full list of equipment for (given) car?
Is there a cheat sheet which could help me to decode Peugeot/Citroen VIN numbers?
Finally, i found one, kinda useful vin decode page, but all it says is: Trimlevel *High Average*. What is high average in terms of Citroen? link: https://www.vindecoderz.com/EN/check-lo ... XMJJ619429
I guess I could ask Citroen dealership to help me out, but is there a general and generic way to find the trim level and other interesting things which are behind the VIN number?
Also, here is car vertical report https://www.carvertical.com/en/prehlad? ... XMJJ619429
kind a suspicious that there is almost none mileage records.
Citroen C4GP trim level by VIN code or cheat sheet
- x 1061
Re: Citroen C4GP trim level by VIN code or cheat sheet
Dont know how well this will come out when pasted.
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C4 PICASSO / C4 SPACETOURER (B78)
SILHOUETTE ESTATE - LEISURE
TRIM LEVEL HIGH MEDIUM
ENGINE DW10FD FAP 110KW DIESEL
TRANSMISSION STT TYPE 6-SPEED MANUAL GEARBOX
PAINT TYPE METALLIC LACQUER
BODY COLOUR EVL - PLATINUM GREY PAINT
INTERIOR TRIM TYPE CALODRAS CLOTH TRIM "8L"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BVM ML6 CL
DEFINITION TO FOLLOW MID-LIFE
ENGINE (TYPE) EW/DW
Vehicle characteristics
Fuel supply-Engine
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START ALTERNATOR STARTER
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.1 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER CATALYTIC CONVERTER BELOW 50PPM
FUEL TANK FUEL TANK WITH LOCATING TAB
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 X 2-SPEED FAN 140W AERO DYNAMIC FLAP
Gearbox Transmission
GEARBOX TYPE ML6C
FINAL DRIVE RATIO AXLE RATIO 19 X 70
WHEEL STYLE 17-INCH AQUILLON BLACK ALLOY WHEEL 7 J17 CH 5-50
CLUTCH HYDRAULIC CLUTCH
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 205/55 R17 95V REINFORCED TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
Suspension-Steering-Brakes
STEERING (OPERATION) LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR DIAMETER 23 HOLLOW
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
HANDS FREE ACCESS AND STARTING FRONT ACCESS + BOOT + HANDS FREE STARTING
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
AERIAL AERIAL + GPS + GSM
FINISHER (SELF-ADHESIVE) GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (DIMENSION) WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
INDICATORS SIDE MARKER LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
DRAUGHT EXCLUSION FR AND RR DOOR AERODYNAMIC SEALING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + BONNET + WHEELARCH + AC POWER TRAIN
WINDSCREEN WIPER 2 SPEED INTERMITTENT+AUTOMATIC CADENCING
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER B COL FR BUMPER+CHROMED STRIP AND B COL RR BUMPER
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AID WITHOUT PANORAMIC VISUAL AID
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES BODY-COLOURED EXTERIOR HANDLE
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREEN WITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRROR WITHOUT INTERIOR CHILD MONITORING MIRROR
AUDIO PACK AUXILIARY SOCKET 1 JACK SOCKET + USB
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT EVOLUTION 2.0
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
SUPPLEMENTARY SEAT 2 PLACES SUPPLEMENT SEPAR SEATS
BLIND SPOT DETECTION WITH BLIND SPOT MONITORING
LUGGAGE COVER LUGGAGE COVER + WINDSTOP
FRONT SEATBELT PYROT PYROTECHNIC SEAT BELT DOUBLE WITH ALARM
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH HEATER MATRIX
SPEED GRADUATIONS GRADUATION KMS/H
GEAR SELECTOR FLOOR GEAR CONTROL
CONSOLE CONSOLE LONG+STORAGE
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
AIR EXTRACTOR WITHOUT AIR EXTRACTOR
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING WITH GLOVEBOX LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT EQUIPMENT DASHBOARD UPPER SECTION ARDOISE GREY
INT. TRIM AND EQUIPMENT VARIATION CLOTH INTERIOR EQUIPMENT TRIM
MISC. INT. LAMPS LIGHTING BY BULBS
WORK TABLE WITH WORK TABLE
LOAD SPACE TRIM FOAM BOOT MAT + SOUNDPROOFING
UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIM GLOSS BLACK DECOR DOOR TRIM
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
ADDITIONAL BLOWER WITH ADDITIONAL PULSE
PASSENGER COMPARTMENT SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT FR DRIVER SEAT CUSHION ADJUSTMENT RECLINING SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
FRONT SEAT ARMREST DRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN FLAPS IN FLOOR
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS HALOGEN BULB
TRAFFIC INFORMATION READER PREVENTION+CORRECTION OF LATERAL TRAJECTORY
DISPLAY DGT TOUCHSCREEN+12" DFT DISPLAY
OIL GAUGE STD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
ELECTRIC WINDOW (OPERATION) DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
COURTESY LAMP CONTROLS FOR FRONT + REAR DOORS, FRONT + REAR INTERIOR LAMPS
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
WIFI WITH WIFI
RADIO RECEIVER ANALOGUE CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS) SOLID SEAT BACK STORAGE POCKET
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO MONO RADIO TUNER
OBSTACLE DETECTION SYSTEM FR AND RR RADAR OBSTACLE DETECTORS + RR CAMERA+AUTO PK
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION KNOB PVC + CHROME DISC + GAITER IN PVC SURPI
FLOOR MAT W/O CARPETMAT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
STEERING WHEEL LEATHER STEERINGWHEEL
Electrical
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
ALTERNATOR ALTERNATOR ISTT53
HORNS HORNS-HARMONY
BATTERY BATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING FRONT DAY RUNNING LIGHT (DRL)
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
MULTIPLEXING MODIFIED ECONOMY ELECTRICAL ARCHITECTURE
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION SOCIETE (OVSA)
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET TRIPLE 220V ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
Top of the page
6.20.4
ENGINE (TYPE) EW/DW
Fuel supply-Engine
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
GEARBOX TYPE ML6C
Body fittings
HORNS HORNS-HARMONY
Interior fittings
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
Top of the page
6.20.4
