Berlingo 2.0 hdi cooling fan operation
Raul
Unread post by Raul »
Hello
The car is from 2003 and has an air conditioner. The problem is that the fan does not kick in with low speed. It kicks in when the temperature of the coolant is well over 100 degrees. I do not want to blow the head gasket.
I got a lexia tool to help to sort things out. I removed the front bumper two check the wiring of the cooling fan. I found there are two resistors- one is 0,54 ohm and the other is 0.8 ohm. Turns out that atleast the 0.54 ohm resistor is faulty because when I bridged it the fan kicks in with full speed when testing with lexia. I then switched it with the other - 0.8 ohm- resistor and it started to run low speed while testing and also switched to high speed when testing the high speed operation.
The question is - what does the 0.8 ohm resistor do? The fan seems to work even if the resistor is not in place. Is it for air con?
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
x 1061
Re: Berlingo 2.0 hdi cooling fan operation
Unread post by wheeler »
Without looking a a specific diagram for your vehicle the injection ecu normally controls the high & low speeds but the BSI controls the mid speed for the A/C. They can use the resistors together or on their own to achieve the different speeds.
Raul
wheeler wrote: 31 Aug 2022, 10:03 Without looking a a specific diagram for your vehicle the injection ecu normally controls the high & low speeds but the BSI controls the mid speed for the A/C. They can use the resistors together or on their own to achieve the different speeds.
Ok, that is clear now. Another question , just for information - what is the purpose of the diode like thing on the resistor. As much as I understand it is not in the circuit. The socket on the resistor has 3 poles but only 2 wires come into the resistor, so it seems it hangs there without doing anything.
x 1061
Its not a diode its a thermal fuse.
https://www.swe-check.com.au/editorials ... _fuses.php
