Im wondering if anyone can help, the car has just started to feel abit bouncy, so i put car in highest psotion to level car and the put back to normal ride height.
Problem i have now is that rear of car has gone down to normal height but front of car is still in highest position, which makes driving impossible...
Any ideas please ????
Xantia Sphere problems
philhoward
sidog70
Patxi
Patxi
If the height lever is stuck... could be an option.
Open the bonnet and put your weight on the front rail (the one above the radiator).
You could try putting a bit of WD40 (put some wood blocks under the car to maintain it's height before getting under it, just in case...) on the corrector lever before doing the jumping part.
Ciao!
Ciao!
sidog70
AndersDK
May I suggest you get the front height corrector and linkages serviced (well greased), before you harm yourself (or car) [:D]
You MUST have the front of car jacked up on SAFETY stands, then get under it and lube up the linkages. You can see the linkage running from the front anti-rollbar to the HC (Height Corrector), and that a rod connects from the in-cabin height selector.
Spray everywhere you can see these rods/linkages are moving/pivoting/sliding, then keep operating the height lever until all linkages moves freely.
No need to have engine running or car on wheels, as you simply need to first make yourself deadsure everything moves on command from the height lever.
Once you're sure everything moves freely, then finish off greasing with heavy standard/ballbearing grease.
Then get car back on wheels and continue with Citaerobics to make sure it will work.
