Key fob and door lock not working
miljanmax
New User
Unread post by miljanmax »
So today i tried unlocking my car with the key fob and the car doesn’t respond at any distance. I changed the battery but same thing.
Then i tried unlocking it manually in the key lock but it is only spinning, making a clicking noise every 180degree turn and thats it.
Im completely stuck on what the solution might be, as i cannot use my car atm.
Any ideas guys?
x 1939
Re: Key fob and door lock not working
Unread post by Paul-R »
Is there a key lock on the passenger door? Do you not have a spare remote key fob to try?
Ross_K
x 110
Unread post by Ross_K »
Does the same key work in the passenger or rear locks?
If you unlock one of the other doors, does the central locking unlock the driver's door too or does it stay locked?
Did you check this post? viewtopic.php?t=67557
