cabin air blower C4 hatch 2012 dual air con
skragamuffin
Unread post by skragamuffin »
hello all firstly let me please apologise if this subju=ect has been covered b4 but i have read and read many posts abt this subject some talk abt bridging etc but my fusebox is different from those etc....
so my heater blower fan has stopped working its a 2012 C4 hatch 1.6 exclusive all the dials light up speed selector temp display etc but no air/air con this suddenly happened with no pre problems except for abt 9 months ago it done the same but worked st8 away after a restart as said above my fusebox is different from whats in posts i have read so dont know if i can bridge or not where the fuse is if theres a relay etc i can say that i have tested all the fuses in the fusebox engine compartment and the fuses off the battery and they all seem fine any help would be appreciated and the location of the resistor, fan etc
thank you in advance
x 6945
Re: cabin air blower C4 hatch 2012 dual air con
For safety's sake, just get a replacement blower control module.
Details of location here:
viewtopic.php?p=662328#p662328
skragamuffin
hi i have changed this but still nothing im guessing the blower motor is the part slightly above with 2 heavy duty wires from the resistor module? i have removed 2 screws but it still wont come out
skragamuffin
ok so i accidently touched my resistor fins to ground and the fan kicked in so went back through previous posts as i thought i had read some one else have the same but with a different system
and capow with a bit of tracing i found the same burnt out connection replaced it and now everything is fine and dandy
x 6945
Great, thanks for the update.
