DS5 Head Up Display
Shaun 68
DS5 Head Up Display
Unread post by Shaun 68 »
Hi Mark
Could you tell me where the fuse for the HUD on a DS5 is located please 🙏
Reason: New Thread Created
x 6963
Re: DS5 Head Up Display
The fuse is in the passenger glove box, Fuse F32 (10A), however, this fuse also controls the radio, telematics and radio. So unlikely to be a fuse if the other equipment I mentione4d is still working.
Shaun 68
Hi Mark
Thanks for your rapid reply
The radio is still working, so I guess the HUD unit is dead, sounds a very expensive repair.
x 6963
They don't repair these - they will just replace. You could get a second hand one. To remove, you need to remove the instrument panel which also require long pin-type instruments inserted in the top of the instrument panel to release 2 internal securing clips, then a series of trim clips on the surround. Then the instrument panel can be carefully lifted to allow access tot he wiring plugs and removed. this exposes some securing clips for the instrument panel shroud which has to be removed, then this exposes some securing fittings for part of the HUD. Then the HUD surrounding trim on the dash surface can be unclipped to expose the main bolts, to release it and disconnect the unit.
If it is being replaced it needs a diagnostic tool to reinitialise it.
Shaun 68
Will any garage be able to initialise it or does it have to be a dealer. I have seen a few on ebay but are from older cars than mine ( 2015 ), would that be a problem.
x 6963
I can't tell you what is involved in the procedure - only that this is required if replaced. So whether that is referring to a new unit or not I can't advise and whether fitting a unit from the same vehicle with same options will just work or not. Generally these sorts of capabilities are only available using dealer-level equipment like Diagbox.
