Does any know how much transmission oil to put in after draining Gear Box model number 9650882910.
Car model Citroen C2 1.1 2004.
Had some leak after changing spring when the cv shaft came out, not sure how much oil was lost and this model does not seem to have a dipstick or level plug.
Most citroens transmission seem to have 2 liter to refill after a drain, but the supplier of the gear oil said my car transmission showed up with a capacity: 2.35 - 2.65 ltr.
I am aware that only a flush removes all the oil, but I am only planing do a drain and refill. How much oil do I need to refill this gearbox after a drain?
Thanks for any info.
Gearbox with no dipstick or level plug
- x 1061
Re: Gearbox with no dipstick or level plug
Regular manual gearbox or Sensodrive?
Paul 2020
Its a manual gearbox
- x 6950
There are also 2 types of manual gearbox that could be fitted, so best to pop your VIN up if you are not sure:
The 'BE' gearbox takes 1.9 Litres when empty and the 'MA' gearbox is 2.5 litres.
Paul 2020
I have noticed of the forum that VIN numbers are hidden, if I post the VIN would it be public or only read by forum staff.
are there specail character I have to put around the number to hide it?
- x 6950
No, just type it in normally with no spaces and when you submit your post it will be automatically masked to the public
Paul 2020
Thanks Marc Here is my VIN: VF7**************[VIN obfuscated, can be read by forum staff]
- x 6950
Ok, so you have the MA type gearbox:
(1) gearbox drain plug.
(2) filling and level plug.
So quantity is 2 Litres after draining.
Paul 2020
It looks almost the same but there is no level plug shall try to upload photo if thats possable
Paul 2020
The diagram is not the same, mine does not have a level plug, the metal cover is the same and the drain plug is square tool fittiing but the casing is different , there are plenty of images on google and ebay so on with gearbox model 9650882910, any clues, I could risk it and measure what is drained; if below 2 litre or below then fill with 2 litre. what damage would happen if it its too low or high by 100ml or so.
- x 6950
All I can tell you is what is listed. Your build date is 10122 (26 July 2004)
Gearbox 2223TK up to build date 10191 (3 October 2004) (yours)
CP(16X65)-CT(21X18)
MARKING CPB0 (CPB0) CP20
It was replaced with Gearbox 2223YC from build date 10192 (4 October 2004) to 12165 (28 February 2010)
CP (16X65)
MARKING (CQA2) CQA2 CQ12 CPB0 (CPB0) CP20
CP(16X65)-CT(21X18)
CP (16X65)
