Vacuum solenoid location and missing vacuum pipe??
Jedders
x 3
Unread post by Jedders »
Hi everyone,
Whilst trying unsuccessfully to locate the vacuum solenoid on my C5 X7(help), I noticed what I think is a missing vacuum pipe. Having fished around the back of the engine I couldn't find anything to connect to it. So I'm wondering if this could be the cause of the fault codes kindly deciphered in my previous post. I've attached a couple of photos.
Thanks in advance
KennyW
x 165
Re: Vacuum solenoid location and missing vacuum pipe??
Unread post by KennyW »
There 3 or 4 solenoids at the back of the engine depending age of your C5. All have vacuum pipes attached to them. With a pipe running to the vacuum pump situated next to the HP fuel pump.
Any holes etc in these pipes will affect the vehicle.
Some of these hoses are a PITA to get to and replace.
Kenny
C3 1.4 petrol (SWMBO)
Jedders
x 3
Hi Kenny
Thanks for the info, the car is C5 X7 2.0 HDI does anyone have a diagram of the vacuum circuit?
x 6950
Jedders
x 3
Hi Marc
Looking at the 3 pictures halfway down the post. The 3rd picture shows what looks like a blanking cap on the pipes to the far right?
Thanks for the pointers.
x 6950
This one?
I can't see any blanking of the pipes.... (40, (5) & (6) are the electrovalves, but I can't see any blanking parts.
Jedders
x 3
Hi Marc,
Found it trawling through ebay looking at engines for sale!
download/file.php?mode=view&id=46155
Possibly for sitcking the vacumm guage?
KennyW
x 165
Jedders,
What year and engine type is your C5 ?
It maybe relevant. From the photo that looks like a electrical connection possibly for the solenoid for EGR valve. I'm only guessing as the plastic pipe to the left, is that going to the Turbo.
Kenny
Jedders
x 3
Hi Kenny
It's definitely a tee piece that's part of the vacuum circuit not an electrical connection.
KennyW
x 165
Okay, There is a vacuum pipe which has a 'T' piece which runs from vacuum pump to solenoid back to EGR valve. I have this one in the shed.
Can you confirm your engine and year of manufacture.
Kenny
Jedders
x 3
Hi Kenny,
I have the pipe with the tee piece but didn't know what was connected to it. I assumed there was a missing vacuum pipe connected to the 3rd outlet of the tee but it looks like it is a blanking plug not a 3rd pipe. I've stuck a bit of tape over the end whilst a work today and the car did seem better driving home.
KennyW
x 165
yes It is blanking plug, the slightest hole will cause problems.
Kenny
Jedders
x 3
I just need to sort the vibration now but that's another story. The thing is I very been hooked on citroen since my first Xantia and they were a lot easier to work on.
Thanks for everyone's help.
admiral51
(Donor 2026)
x 392
Unread post by admiral51 »
Just an idle thought but would These be suitable to blank the T
Colin
Jedders
x 3
Hi Colin
I made one with a a dust cap and o ring
