WIRE DIAGRAM FOR NEMO
sparxBM
Unread post by sparxBM »
Has anyone got a wire diagram for 2010 plate UK Citroen Nemo van? I am looking for to fit an after market alarm and need the wire connections for the central locking , open and close to attach a bluetooth activated relay . . thanks in advance
sparxBM
Re: WIRE DIAGRAM FOR NEMO
OK been a while and surprised noone here has an electrical knowledge or diagrams of this problem. . so please anyone out there got an answer or info?
x 1061
Unread post by wheeler »
You need to provide the VIN or reg number to get the correct wiring diagram for your vehicle.
sparxBM
reg no ND60LCO VIN VF7**************[VIN obfuscated, can be read by forum staff] . .Hope this helps, look forward to any assist
x 6950
This should be the one.
Most of the component codes are on the Wiki:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
sparxBM
Thank you GiveMeABreak for diagram, so I can see that the actuators/motors are triggered from BSI1: built-in systems interface at cables 99 & 100 or pins 32 & 16. so will still need to strip down to get to BIS . .or strip door and look at pins 1 & 6 to get colour code of cable at multiplug inside van . . unless someone has colours of tghe two cables?
x 3298
Be aware that Citroen wiring can change colour along its' length (which often causes confusion). However, there will be a code printed every few inches that remains constant along the full length of that wire.
x 6950
Stick to pin numbers and wiring sleeve codes.
