c3 wipers on intermittent all the time
mylo c3
Unread post by mylo c3 »
Thank goodness I found this forum!
My 61 plate c3 has its wipers on intermittent constantly and it’s becoming a pain. I’ve done some searching and tried to reset the control module which worked for a day or two but not now. Is it the motor gone faulty and this is the way the comms tells you?
Is it the switch faulty and the comms telling you??
Or is it the comms itself???
x 6950
Re: c3 wipers on intermittent all the time
It really depends on the fault code which should be triggered and for which you will really need Diagbox to retrieve. There are possibilities that range from the form the speed control wire, the engine fusebox, the wiper motor itself or the comms unit or data network wiring. So a fault code is really needed to give you some pointers.
mylo c3
thanks Marc- I will get that looked at and get back
x 1061
Unread post by wheeler »
The first thing i would do with this is check the live data of the Com2000 unit (wiper & indicator switch assembly) & see what position the BSI thinks the switch is in. If the live data is showing the switch working as it should i'd next take a look at the wiper motor and its connector for ant signs of water ingress.
mylo c3
can the live data be read with a mechanics style diagnostic or is it more specific for electronic systems? My garage has been on holiday this week but will be there on monday.
Would the key transponder battery being down have an impact??
x 1061
mylo c3 wrote: 13 Aug 2022, 17:18
No.
Any decent professional level diagnostic system should be able to read this, The diagnostics often list it as 'switch module at the steering wheel'
mylo c3
cleared all the codes at garage today and reset the body module as per instructions- all ok and checked through the operations several times - drove away and they come on again ahhhgg!!!!
x 6950
Unfortunately clearing the fault code is useless if the fault remains - it will just get triggered again, so needs some further investigation to try and determine if it's the comms module (control unit under the steering wheel). We had to have ours replaced as a result of the automatic headlamps activating during the day and flashing oncoming drivers randomly, but wipers were fine.
