I have a 98 hatch Xsara and have a damp rear edge on my carpet
sometimes. If I use the hose on the car I see no water ingress. I
wonder if it is condensation running down from the rear window and
onto the trim then into the boot though it may well be from outside.
Anyone have any experience or tips?
Colin
Xsara 98 hatch leak in boot
The rear seal / trim that is on the boot hatch (on the car) is some times not that tight when the boot is shut and you get a little but often water ingress. This leads to a damp carpet. I think the only way is to adjust the rear boot lock so it's a little tighter on the seals. Not to much as you may not be able to shut the boot. Slightly slacken the clamp on the boot lip and adust then re-tighten. To dry out if you ain't got a garage try some news paper under and on top of the carpet this will soak up the moisture.
