Additive Tank Suppliers
cs101
x 6
Unread post by cs101 »
Hi all! Part Number 9817154080 (Fuel additive Tank) very hard to find and all dealers say they are out of stock. Anyone recommend where to find please. Thanks
x 6957
Re: Additive Tank Suppliers
I've moved your request out of Official parts requests as you have the part number now. All you have to do is just Google that part number on its own and there will be plenty of suppliers coming up. :wink:
x 3566
....plenty of suppliers coming up..... very little stock anywhere 8-[
x 1942
Unread post by Paul-R »
That's what I found as well. Which is why the OP made his post here I'm sure.
If it's urgently required it might be time to look at getting it from Europe. Or possibly a second hand one from a breakers' yard.
I hesitate to mention it but one hit came up on Ali Express...
x 1942
Paul-R wrote: 04 Aug 2022, 15:40I hesitate to mention it but one hit came up on Ali Express...
But even they're out of stock!
x 1942
Perhaps a different approach.
@cs101
What's wrong with the old tank? Could it be repaired?
Just found these breakers in the Netherlands. Worth giving them a message?
https://www.boonstraautoparts.nl/search ... k/13533706
Huskyxantia
x 906
Unread post by Huskyxantia »
Ebay ?
:-D
x 3566
Huskyxantia wrote: 04 Aug 2022, 17:14Ebay ?
Not under that P/N. There have been in the past, but nil at the moment.
Huskyxantia
x 906
Hope you source one.
bobins wrote: 04 Aug 2022, 17:41
:-D
cs101
x 6
Paul-R wrote: 04 Aug 2022, 15:54 Perhaps a different approach.
@cs101
The fault had come needing new pump.
x 1942
Where has that message come from? Presumably a code reader of some kind - name please. What error message code (or codes) is/are flagged up?
cs101
x 6
Paul-R wrote: 13 Aug 2022, 16:51 Where has that message come from? Presumably a code reader of some kind - name please. What error message code (or codes) is/are flagged up?
Sorry for the late reply. The garage had their own diagnostic equipment. Sorted now as fitted with second hand tank they got from breakers yard.
x 1942
That's good to hear and, judging by the posts above, lucky! How much did it cost?
