Citroen Dispatch Rear Door Issue
SKYDIVER
Unread post by SKYDIVER »
"Hi, Can anyone help?
We have an issue with the central locking of the rear door. All other doors lock ok, but when you try the rear door with the handle, it opens and then unlocks all the other doors.
If I lock the rear door with the key, this then locks all the doors on the van, and will unlock all with the central locking fob when pressed.
But will not lock the rear door with central locking.
I have replaced the rear locking mechanism unit complete, and no difference.
Please can anyone HELP......"
x 6950
Re: Citroen Dispatch Rear Door Issue
What is the VIN of this vehicle. There are different locking options that can be configured for commercial vehicles and these can be configured with a dealer level diagnostic kit. Some may be able to have options changed from a configuration menu, but I may have a better idea once I have the info I asked for.
x 1061
Unread post by wheeler »
My first thought would be broken wire(s) in the part that flexes all the time where the wires go between the body & the door.
Scott11
New User
Unread post by Scott11 »
I have the same issue so following
