Oil.
Huskyxantia
x 904
Oil.
Unread post by Huskyxantia »
:roll:
Just did an oil change on the 206cc ive used a flush in a warmed up engine which i let run for 10 mins as what the can said ,then drained it all out, i let it be went inside had my dinner then back out pop the new filter in do sump nut back up have a clean up the refill with oil . Now i filled my jug to under 4 litres so now im in panic mode :( :( :( :( :( :( as its has about 3.8 or just over of oil .. so have i over filled it on the stick it was top of the markers more or less as it was when i dipped the car before i got it last April. I've used a low soot oil too.
:-D
x 1486
Re: Oil.
Supposed to be 3.75 with filter, so sounds like you are pretty much spot on?
Huskyxantia
x 904
Re: Oil.
I've drove it today seemed ok so i must of done it right .
:-D
