can anyone help?
kangoo 1.9d 's reg'
turn the ign key usual lights come on, try to start and there is a faint click (probably a relay) and nothing else.
the oil, batt, and glo lights then flash continously on the dash.
Kangoo - wont start
mikgram
the click could be the solenoid on the starter motor.
turn the the ignition to the first stop to release the steering lock.
put the car in 5th gear with handbrake off obviously on flat ground,
push the car about half a meter back and forward several times put the car in neutral and try the key ,if it starts then the solenoid or starter moter is on its way out .
also try look at the solenoid there will be a small wire on a spade connector take it off clean it up and if its not tight sqeeze it slightly with a pair of pliers.also check battery for charge and that the leads are tight.
