Citroen Xantia LHM leak
CarbageRun2022
Unread post by CarbageRun2022 »
hi guys,
all of a sudden the steering of my Xantia stopped working.
I barely got the car to the side of the road and mentioned that the LHM was leaking quite badly.
Refilling did not work as much since it poured it all out immediately.
It seems to me that the return hose is leaking and that I could fix it with a replacement set
See those YOutube videos for the leak
Any tips on this?
x 1486
Re: Citroen Xantia LHM leak
Unread post by xantia_v6 »
I can't see which angle of the engine bay you are filming, but I guess that it is the return from the pressure regulator. A replacement part may be available, what date is the vehicle, which engine, and is it hydractive?
x 1486
