Dog pee ...
Huskyxantia
x 917
Dog pee ...
Unread post by Huskyxantia »
:shock:
New car stinks of dog pee ..
How do i take the carpet out 307sw ?
This heat is cooking the pee pee
:-D
x 1939
Re: Dog pee ...
Unread post by Paul-R »
I would investigate using a wet vacuum cleaner. Far easier than taking the carpets out. I used one last year to remove (nearly) all traces of several litres of spilt Adblue in the 308.
You'll need one with a hose and attachments. A stand-up type (unless it comes with hose, etc) won't be suitable.
EDIT
This is what I used https://support.vax.co.uk/pet-vax-multi ... m-cleaners
You need to make sure it comes with the the reservoir though. https://support.vax.co.uk/universal-res ... __store=22
x 5672
Re: Dog pee ...
I bought a Titan wet/dry vac ftom Screwfix a few years ago and found it very useful.
Aldi and Lidl have similar looking ones for a bit less.
Warning!
I have found a lot of jobs for it since. They make work :twisted:
x 1240
Re: Dog pee ...
Unread post by Peter.N. »
I bought a cheap XM estate that smelt like that, couldn't get rid of it until I cut down a eucalyptus tree and loaded it into the car, it stayed there for about a week, when I eventually unloaded it the smell had all but gone. I wouldn't suggest you did the same but wonder if eucalyptus oil might have a similar effect?
x 1074
Re: Dog pee ...
Unread post by Rp0thejester »
What ever happened to shake and vac should work well. But I do agree, a good wet vacuum cleaner will do the job, if you don't know anyone whose got 1, you can hire them from supermarkets and do the house as well. Should dry well quick in this heat.
x 3296
Re: Dog pee ...
I have found that a good citrus disinfectant seems to shift most nasty smells. If I have got diesel on my hands a lemon/orange handwash shifts it nicely.
Huskyxantia
x 917
Re: Dog pee ...
Peter.N. wrote: 19 Jul 2022, 12:27 I bought a cheap XM estate that smelt like that, couldn't get rid of it until I cut down a eucalyptus tree and loaded it into the car, it stayed there for about a week, when I eventually unloaded it the smell had all but gone. I wouldn't suggest you did the same but wonder if eucalyptus oil might have a similar effect?
My neighbor has said tree ........ i have chainsaw.........
:-D
Huskyxantia
x 917
Re: Dog pee ...
Well , i did it the hard way took the carpet out pressure washed it with a snow foam and hand brush scrub then a blast. Hell Razor5543 kindly gave me a spray foam the other day which i will be using at the weekend on the seatbelts as they are not retracting quick enough
:-D
x 1074
Re: Dog pee ...
Spray foam for retracting seatbelts, do tell!!
x 3296
Re: Dog pee ...
The foam is a fabric cleaning foam from Poundland (and I have found it does a good job of cleaning), and I have also recommended a silicon lubricant spray (such as that from Screwfix Direct) to then lubricate the belt.
https://www.screwfix.com/p/floplast-sil ... 40ml/3290f
AlvinCitroenC5
x 3
Re: Dog pee ...
Unread post by AlvinCitroenC5 »
Pet stores usually sell a spray that break down pet urine enzymes, which I find works very well.
nikeastwood
x 24
Re: Dog pee ...
Unread post by nikeastwood »
can also use an Ozone Generator, it kills organic smells and is good for that, cars that have been smoked in, and if milk has been spilled and gone off in it.
no egr, no dpf, no problems.
Huskyxantia
x 917
Re: Dog pee , 307sw new life with me.
Huskyxantia wrote: 18 Jul 2022, 13:46 :shock:
I'm using this thread to keep a history of my recently acquired 307sw, its to keep it all in one place.
My first service was today 20.8.22
101395 miles
All filters
New oil
Resetting the service counter ... 6400 miles ? To the next service Surely not as soon as that... any one ? :shock:
:-D
x 5672
Re: Dog pee ...
I cleverly released a large quantity of milk onto the rear seat last weekend.
Que the garden spray followed by the wet vac, repeated several times.
A slight miasma a couple of days ago so can't have got all of it, but tolerable and diminishing.
Luckily son has the car this week.
Huskyxantia
x 917
Re: Dog pee ...
Milk can be bad. Took some stuff to the tip today one bag leaked something ? Washed it off the rubber boot mat caught it just in time i hope !
:-D
