Opposite to Antifreeze.
x 1083
Unread post by Rp0thejester »
We all add antifreeze for the colder months, with the way the climate is changing is there an antiboil for these 30degree heats that we are experiencing?
x 6950
Re: Opposite to Antifreeze.
A properly maintained coolant system shouldn't need anything added at all. They are factory filled with long life protection and should only need checking as part of regular servicing. A coolant is already designed to prevent freezing as well as overheating.
x 1083
Okay, car had engine replaced before I bought it, so no idea if they put the correct coolant in. I'll ask in genuine parts.
x 1955
Unread post by Paul-R »
My bottle of "radiator filler" says Anti-freeze and Summer coolant on it. So... nothing extra.
x 1083
Okay, dunno what mine was filled with, hopefully not just water. I do have antifreeze in the glove box but topping up water with antifreeze is gunna take forever as I have no leaks
x 2938
Change it to be sure, I had a young chap ask if he could sell his Hillman Avenger off my patch in late autumn, I asked if it had anti freeze and he said it had, car took a while to sell and after the first hard frost of the winter I found a four inch square piece of cast iron from the block lying under it. :shock:
x 1083
Ouch
Sloppysod
x 407
Unread post by Sloppysod »
Be careful of using 'tap' water to top up / fill your cooling system as some hard water areas could scale up easily.
Since my motorcycle days I have always used distilled or de-ionised water.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
