GSF PART NUMBER CHECK
surfer
Unread post by surfer »
Jon,
A couple of questions:
HT lead set N92632 is listed for the 2.0 8V Xantia.
Do these fit the Activa also?
And radiators ~ the online catalogue doesn't list a part for the Activa, but my printed catalogue lists N17370 as fitting the 2.1TD and the 2.0 turbo.
Can you confirm if it fits please? And is it a Valeo item?
The car is a '96 P and RP 7168 if this helps.
Thanks for the info on the spheres by the way. The markings were just as you said.
Simon.
Jon
Unread post by Jon »
N17370 radiator is fine for the Activa, listing 2.0 Turbo is slighty confusing because the only 2.0 Turbo Xantia's that we got for the Uk market were Activa! As for the make we have 3 suppliers for this part, Valeo, Ordonez or Nissens, and the stock could be any of those 3 makes depending on Branch or date.
The N92632 HT leads will be fine for 2.0 Activa.
Richard Gallagher
Unread post by Richard Gallagher »
The Activa the only 2.0 Turbo Xantia in the UK, what about the estate Turbo CT?
Jon
Ok Ok Ok. How many of those were there.[:)][}:)]
As an aside when the 2.0 CT was launched I happened to be on a Citroen UK training event at Slough. Someone asked what "CT" stood for. The answer was that there was so much torque that it meant the Canine's Testes![;)]
