Hi all
I just got a 1.9D ZX and there is a mechanical knock from the engine, I have removed the pistons and rods and all the bearings seem fine the camshaft and bearings also look OK the pistons and rings are also in very good condition ( I think the engine have been refurbed as the car has done 207,000 miles ) the only thing I found was the the oil pump chain seemed a bit slack, could this be a problem ( I have never worked on these before ). The only other thing I could think of is that there might be a problem with the injectors or pump, will the parts of a 1.9 CX engine fit? ( XUD )
any ideas you guys can give me will be a great help.
The knock is at all revs and get louder when reved up, engine is a bit hard to start and all glow plugs are working fine. Oil presure seems fine and no excess presure build up in the cooloing system
1993 ZX 1.9D enigine knock
Dave Burns
sparks
Thanks Dave
I will be rebuilding the engine in the next few days, if the noise is still there then the injector is at fault, since this car is new to me I will a;so be changing the cam belt, alt belt and filters.
PS I might be getting rid of my BX soon, its a BX19 estate with a 1.7 Turbo engine. Suspension and engine are working fine just the windscreen is damaged and the MOT has run out.
