How much gas in C4 BlueHDI cactus?
martin_b
(Donor 2022)
x 8
Unread post by martin_b »
So I had an aircon service on my C4 Cactus BlueHDI 2014 yesterday. Before the service it didn't cool at all, and now it blows cold. Not as cold as I had come to expect from my previous car (Suzuki Grand Vitara), but it's cold now.
There's still some noise from the aircon pipes when I turn on A/C, especially the first 20 seconds or so. I expected it to be completely quiet.
Could you look up how much gas the system needs, GiveMeABreak? According to my receipt it needed 295 grams of R1234YF but I think it needs a little more. My previous car went completely silent when I had put in the correct amount of gas.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Cheers
Martin
x 6955
Re: How much gas in C4 BlueHDI cactus?
For the C4 Cactus: 1234Y refrigerant: 365 grammes for the refrigerant charge. This is of course for the complete charging of the system - not the amount that they may have topped it up by, so bear that in mind.
If they have done a full proper service, then they should of vacuumed out the system, disinfected it and then replaced with the correct amount.
martin_b
(Donor 2022)
x 8
They have done a full proper service, I have no evidence to the contrary. Thanks for telling exactly how much should be in the system. They pulled a vacuum and the system contained 60 grams and they added another 295 grams, so that's pretty close to a total of 365 grams.
There's a gurgling sound for a short while when I turn on the A/C but it goes away. I expected it to be completely quiet, but mine is not. Mechanic says it could be the "dry filter" of the system that could be a bit clogged. I don't want to spend more on it so I will live with is as it is now.
x 6955
No worries - keep an eye on it. I assume they leak / pressure tested it too when they serviced it?
martin_b
(Donor 2022)
x 8
Yes, they pulled vacuum for 1 hour and made sure there were no leaks.
