principle relay
Tigerryes
principle relay
Car broke down whilst towing our caravan. Engine fault, repair immediately light, esp not working and handbrake failed, even though it did work and the car went into limp mode. Brakedown cleared the code and we went on 2 miles before it happened again. Got took home. Local garage couldn't read some codes but Peugeot garage was saying particulate filter blocked (no low adative or warning lights) glow plug system fault, could be plugs or relay and the last thing suggested was it could be the principle relay??? Wtf and where can you get one? Is a thing we can change our selves. TIA
2012 Peugeot 3008 2.0 hdi
- x 1072
Re: principle relay
What car do you have? Also mileage and VIN so others can help where I can't
Champion of Where's CitroJim
Tigerryes
Re: principle relay
sorry i didn't get back to you, we found the principal relay, it's the glow system replay also called primary relay. had that and plugs changed. seemed ok for quite a lot of miles before throwing a wably with somethng else which i've put a new post up about 'faulty sensor'Rp0thejester wrote: 01 Jul 2022, 22:38 What car do you have? Also mileage and VIN so others can help where I can't
