Hi All,
I've searched but cannot find an answer for the process to reset my warning lights manually on a 1.6 16v Mk1 Megane
Can anyone help?
Youtube etc all seem to show everything but my model & dash/buttons setup!
History - had a coil go out on me yesterday which put a bunch of lights up. Replaced coil and car running fine but the Engine Management has remained on and I cant seem to clear it.
Already tried holding the end of the stalk in, switching ignition on and off in succession too.... would rather avoid disconnecting battery as not sure I have the radio code!
thanks
Matwylde
Renault Megane Mk1 amber Engine light
- x 1488
Re: Renault Megane Mk1 amber Engine light
Usually you need a diagnostic tool to re-set the light. However, if the fault is now cleared, then the light should go off in a few starts.
Matwylde
RichardW wrote: 21 Jun 2022, 14:37 Usually you need a diagnostic tool to re-set the light. However, if the fault is now cleared, then the light should go off in a few starts.
Thanks for this RichardW - half a dozen journeys later the light went off and (so far at least, fingers crossed!) its stayed off
