AX 1.1 - need some tech help (kind O/T)
Patxi
Unread post by Patxi »
Hi guys!
Just a quick (?) question. Where can i find a signal on an AX 1.1, from around 1991 (carb version), to make a tachometer?
Some kind of wire coming in/out of the electronic ignition unit?
Thanks!
AndersDK
Unread post by AndersDK »
On ignition coil, low tension terminal CB (points) signal.
Patxi
Could you be a bit more specific please, Anders? Kind, wire colour? I have a yelow one sticking out...
Thanks!
volcaneoptimist
Unread post by volcaneoptimist »
No harm trying either one of the two terminals but not the high tension one usually in the middle.
